tmatejuk
how to access ftp site ?
hi,
I'm new to xilinx.
Lately I bought nexys 4. I try to use it under xubuntu with vivado. Vivado instalation went well, but I have problem with cable driver instalation, and windriver6, ... so I didnt connetced to development board yet.
The are some useful tutorials about how to resolve my problems but they ftp://ftp.xilinx.com and I cannot acess it (530 Login incorrect).
What login/pass should I use?
thx.
athandr
I doubt if the ftp site is still up.
Below is the method to re-install the Jungo Drivers(cable driver - windriver)
 (1)    In a command prompt browse to your C:/Xilinx/10.1/ISE_DS/ISE/bin/nt directory on 32-bit installs. i.e. type cd C:/Xilinx/<ISE_VERSION>/ISE_DS/ISE/bin/nt
 Check the figure below on where to access the ISE command prompt. If you are using a windows XP PC, you need to check under All Programs (under Xilinx Installation)
(2)    To uninstall the jungo drivers type the command:  wdreg -compat -inf windrvr6.inf uninstall
 (3)    To reinstall the jungo drivers type the command:  wdreg -compat -inf windrvr6.inf install
Let me know if you still have some problem after doing this.
Anirudh
athandr
One more related AR - http://www.xilinx.com/support/answers/44397.html
Anirudh
tmatejuk
I didnt mention that I use linux(64). Files from ftp that I was looking for may help me with windrive compilation ( i still have problems with compilation ).
Do you have experience with nexys development boards? Can I use it only with usb cable?
And you mentioned ISE and I try to use Vivado, are those ide's exchangeable ?
vuppala
Can you paste the ftp link here?
So that we will try download the files and share them with you.
