technovlsi
how to get output waveform of dds logicore through modelsim?
sir, i am using DDS logicore.setting up its parameters iget the vhdl code,but when i simulate it through isim,it gives error,can't get the output. how will i get it sir?
eilert
maybe it would be a good idea to post at least the error message to give a hint what may be the cause for the error.
Have a nice simulation
  Eilert
technovlsi
module test;
            // Inputs
            reg clk;
            reg we;
            reg [27:0] data;
            // Outputs
            wire [5:0] cosine;
            wire [5:0] sine;
            // Instantiate the Unit Under Test (UUT)
            dds_compiler_v4_0 uut (
                        .clk(clk),
                        .we(we),
                        .data(data),
                        .cosine(cosine),
                        .sine(sine)
            initial begin
            clk =0;
            forever#10 clk=~clk;
            end
initial begin
                        we = 1;
                        data = 60;
                        // Wait 100 ns for global reset to finish
                        #100;
                          we = 1;
                        data = 70;
                        #100;
                          we = 1;
                        data = 50;
                        #100;
                          we = 1;
                        data = 80;
                        #100;
                        // Add stimulus here
            end
endmodule
ERROR:HDLCompiler:559 - "C:/Documents and Settings/Administrator/Desktop/test.v" Line 37: Could not find module/primitive <dds_compiler_v4_0>.
sir , in the bold line error is coming.
ywu
Please do not cross-post the same question. It makes harder for people who try to help. I replied to the same question on the DSP board below:
http://forums.xilinx.com/t5/DSP-Tools/error-in-simulation-of-DDS-LOGICORE/m-p/177372/highlight/false#M4427
Cheers,
Jim
