how to limit routing by pblock
I need to force all routing of one module or partition to use only one pblock.
I need to save all routing outside the pblock clear.
Obviously that's not possible. Clock & IO will need to be routed to the pblock. What are you trying to accomplish by this very strict requirement?
you can implement partition without connected IO while clock is accessible in whole clock zone and neednt be routed
