Newbie yxl
how to set enable_mmc in SDK
hi
i want to boot zedboard from QSPI+EMMC,i placed the FSBL on the QSPI flash and all the other partitions are on eMMC flash.
i want to know how to create a BSP with the library and set enable_mmc in the SDK options. how to find this enable_mmc setting?
thanks
Re: how to set enable_mmc in SDK
1) edit the system.mss and select modify the BSP settings
2) in the Board Support package Settings window, set enable_mmc to true
Thanks and Regards
Balkrishan
Create a BSP with the library and set enable_mmc in the SDK options. For more details, see the library documentation
http://www.xilinx.com/support/documentation/user_guides/ug821-zynq-7000-swdev.pdf
Thanks and Regards
Balkrishan
Newbie yxl
i can’t find detail information in ug821.
thanks
Newbie yxl
could you please show me where can find it ?
Thanks and Regards
Balkrishan
Newbie yxl
I have tried,but i didnt find enable_mmc flag .please refer to the attached BSP.pdf
Observer lophope
One another question:What's the fs_interface value when MMC is enable?
Visitor dev_123
For me this option is not coming
I am using below xilinx SDK version
By the, I want to use MicroSD instead of eMMC , but for me it's selecting eMMC :(
I am using Avnet Ultrazed-EG with IO Carrier card
Thanks in advance !!
Participant amassa
Is there an update to this? I need this option as well but see this setting was removed in 2016.4.
