implementation
hello
it's my first time using FPGA, i want just to know, all the externe circuit that i must put with the fpga to make the supply( horloge, quartz...)
best regards,
Scholar u4223374
Re: implementation
For a typical FPGA, the minimum external circuitry is:
- Power supplies. Most FPGAs will use at least two different voltages (core and I/O), and depending on what I/O you want to use you might end up with 5+ voltages. Each has very tight tolerances, and most can draw substantial current - 20A+ is not uncommon.
- Passive power supply components. An FPGA will normally be surrounded by decoupling capacitors.
- An oscillator. Most boards include a 50MHz - 100MHz oscillator, which you can multiply/divide inside the FPGA. I may be wrong, but I don't think modern FPGAs include the circuitry to directly drive a crystal (like a microcontroller would).
- Configuration memory. FPGAs (with a few exceptions) lose everything when you turn them off, so they need a bit of flash memory that they can load their configuration from. Depending on your system, you may opt to remove the flash memory and have a microcontroller program the FPGA directly. Or, with the Zynq chips, you can use an SD card as the initialization memory.
Scholar u4223374
Re: implementation
Re: implementation
thank you,
I didn't get the third point
me I want to use a FPGA with System frequency up to 100 MHz, so how can I devided this frequency with a oscillator
Scholar u4223374
Re: implementation
abbassioussama1949@gmail.com Have a look through the Xilinx 7 series clocking resources user guide. The Xilinx Clock Management Tiles can multiply or divide an input clock to give a lot of flexibility in the output clock speed. The result of this is that you don't have to choose your input clock very carefully; from a 50MHz or 100MHz input clock you can generate almost any clock frequency you want.
