Visitor presstek
merging data into a "bin" file
I have a product that must be calibrated as part of the manufacturing process. The calibration data must then be stored in 2 files and merged with a "default" FPGA bin file. The problem is that this process works fine on our engineering computers, but the manufacturer is a seperate company and does not have xilinx software. I have tried downloading the "WebPack" and "Developers Toolbox" but neither of them works.
So, my question is, is there an easy way to generate a bin file without purchasing a xilinx license for every calibration station just so we can run bitgen ?
Instructor
Instructor
Re: merging data into a "bin" file
I think you want to look at "data2mem".  If the data you merge with the existing bitstream ll goes into
block RAMs, this utility allows you to merge the file data into the bitstream after running bitgen, so
you wouldn't need bitgen in the manufacturing system.  data2mem was developed for merging
embedded processor code into a bitstream, but there's no reason it can't be used for other
purposes like your calibration data.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/data2mem.pdf
HTH,
Gabor
-- Gabor
Instructor
Instructor
HTH,
Gabor
-- Gabor
Visitor presstek
That worked. I generated a new bit file. Now I'll have to give it to the hardware engineers to see if it's correct.
Thank you gszakacs !!!
