sxg5317
modelsim and ISIM problem on windows server
I got problem when I use modelsim,
I install the ISE 11.1 and modelsim on the virtual machine(XP 64-bit) on windows server 2008,
and remote login to that virtual machine.
when I open the modelsim xe, the error message said "not supported for clients of windows terminal services",
and I can't change to ISIM because it's not installed with ISE.
I installed ISE 11.1 on my PC, ISIM is installed while installing ISE, but not in that virtual machine.
is there any solution for this? or other verilog simulation software that support remote login?
Thank you
