weilings
newbie's question about variable's characteristics
Hey, I have a code as follow:
process(clk)
variable list_head : element_ptr := NULL;
variable temp_elem : element_ptr := NULL;
variable last_clk : std_logic := 'U';
begin
end process
my question:  1. the 'list_head' and the other variables are initialized everytime when the process is triggered?
                          2. is 'list_head' visible out of the process? If the 'list_head' is changed to a signal, is it visible out of the process?
hgleamon1
1. No. Initialisations are power-on values only (and quite distinct from a reset value). Your question shows quite a "software" mentality. You need to think about it in terms of hardware (FFs). How would it be "initialised"? How useful would it be if it were "initialised" every clock (as you have a clocked process)?
2. No, variables cannot be used outside of their defining process. Making the variable a signal will allow it be used by other processes (note that you should only assign a value to a signal in ONE process).
Howard
"That which we must learn to do, we learn by doing." - Aristotle
hgleamon1
Howard
weilings
Thank you very much for your reply.
As for the "Hardware" mentality, I will try.
What do you mean by "assign in ONE process"? Do you mean we can "read" the signal in many processes, but can "write" in ONE process?
hgleamon1
Regarding signal assignments, that's exactly what I mean.
It's a situation that trips up many people, newbies and more experienced designers (although usually with more complex designs) and can be a source of simulation frustration.
Good luck.
