opencv
hi
i was trying to create traffic sign detection previos run but i got the same error again and aigain i was atatching the files and error below any answe will help me
regards
sharmila
Voyager
Voyager
Re: opencv
What are you trying to accomplish?  Are you trying to use OpenCV in a C/C++ environment?  Are you trying to use OpenCV in an HLS environment?
If you are trying to build an HLS project, you need to compile using the HLS tools.
If you haven't already done so, you could take a look at the UG871:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug871-vivado-high-level-synthesis-tutorial.pdf
For HLS OpenCV help, you can look at UG1233:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug1233-xilinx-opencv-user-guide.pdf
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
Re: opencv
hi
thanks for your quick reply am not using opencv HLS i was run it in normal compiler command
in linux
g++ -std=c++11 main.cpp `pkg-config --libs --cflags opencv` -o main
