jamesjisun
pip in switch box is buffered?
I used XDL to export the detail circuit inside the switch box, and found all pips are "->" which means buffered I guess. so it means there is no unbuffered pip in switch matrix?
I am using virtex5 LX110t and spartan 3a xc3s700a.
thanks...
rcingham
Just because they have a patent doesn't mean that they have to always use it.
"If it don't work in simulation, it won't work on the board."
austin
j,
All interconnect is buffered since Virtex.
Austin Lesea
Principal Engineer
Xilinx San Jose
jamesjisun
Hi Austin,
Thanks for your quick response! But I found even in Spartan3A, it is also buffered... However, regarding to patent attached (filed by Sridhar Krishnamurthy from Xilinx), it should be able to configured to buffered or unbuffered... This patent is not used in any Xilinx FPGA?
eteam00
Professor
Professor
I try to avoid the FPGA editor, since the 3K and 4K days (when the FPGA editor was unavoidable).  But I can vouch for the use of buffered and un-buffered PIPs and buffers in 3K and 4K switch boxes.  So yes, they exist in Xilinx FPGAs.
Haven't read the patent, so I can't speak to that.  Is an academic paper the root of your interest, or are you interested in bringing your own line of FPGAs to market?
-- Bob Elkind
SIGNATURE:
Summary:
jamesjisun
I am trying to build some abnormal circuit on the FPGA... that's the reason I need to be clear about its internal connection. And obviously, buffer is not what I want at the moment for interconnection. So my question is how to configure it to be unbuffered if the patent mentioned above is valid in any Xilinx FPGA.
Thanks...
rcingham
jamesjisun
reasonable ...
austin
j,
We do not discuss what we use, or do not use.
FPGAEditor is a programmer's invention to describe the hardware: it is a fantasy, a convenient construction. It has little basis in reality. Sounds like you are doing something very very dangerous.
What is it, and why?
Austin Lesea
Principal Engineer
Xilinx San Jose
