ansarkp
power consumtion in FPGAs
Hi all,
   I am trying to  do FPGA implement for a handheld application. for tha i need some information regarding the power consumtion in FPGAs. I want to know the relation between the resources utilization and power consumed. any links are regarding this are helpful.
Thanks in advance.
Srikanth
barriet
I would start with the XPE spreadsheets.
good information is available here:
http://www.xilinx.com/products/design_resources/power_central/index.htm
This is redirected from the easy to remember http://www.xilinx.com/power and includes link to resources such as the XPE User Guide:
http://www.xilinx.com/support/documentation/user_guides/ug440.pdf (Xilinx Power Estimator User Guide)
bt
patkionkar
if u have the code ready with you, you can directly get the idea of power for the particular code in ISE tool.
Although I do not remember exectly, this option is under PAR options.
