06-28-2013 09:40 PM
06-28-2013 11:44 PM
akkisubhu, did you read my reply in this thread? Did you understand it? You have the same problems in this code. We can't help you if you don't communicate with us.
Also, if you don't even put in the effort to apply proper indentation, why should we put in the effort to help you?
06-28-2013 11:44 PM
06-30-2013 08:37 PM
Sorry for your inconvenience !
but as said i reframed the code and now its giving proper behavioural simulation but the problem arises in post translate simulation as in for simple counter example the post translate model depicts that counter stays in initial state itself plz could u help me out with this problem
06-30-2013 09:00 PM
output remains uninitialized in post translate simulation it does not proceed to further states
07-01-2013 12:00 AM
Post-translate simulation works fine for me. Is the clock signal behaving correctly in the waveform window?
Your code still has a couple of problems, though:
