problem with configuring FPGA
Hi all,
I have Virtex 5 ml507 with Digilent JTAG--USB Cable (which have Digilent 6-pin JTAG header), the problem is that I can't program my FPGA with this cable :smileysad:
You can see his picture in this link :http://www.digilentinc.com/Data/Products/JTAG-USB/ JTAG-USB%20Cable_rm.pdf
in first, is this cable compatible with my carte??
if yes, should I do something do make this work??
or this cable is not for programming FPGA?? is it used only for programming SPI  interface ??
Please, if anyone has a response, help me I'm really stuck!!
Thanks in advance
INES
Re: problem with configuring FPGA
It should work. It's like Cable III but with an USB port. What error messages did you get while programming V5?
hi,
when I search on net I found that I must install Adept from Degilent but when I read the user manual I found that my carte is not supported by this tool.
also, the error message is:
Connecting to cable (Usb Port - USB21).
Checking cable driver.
 Driver file xusb_emb.sys found.
 Driver version: src=1029, dest=1029.
 Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS
12:35:07, version = 811.
Cable connection failed.
Connecting to cable (Parallel Port - LPT1).
 LPT base address = 0378h.
 ECP base address = FFFFFFFFh.
Connecting to cable (Parallel Port - LPT2).
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (Parallel Port - LPT4).
Cable autodetection failed.
 Count ReleaseSemaphore rc = 298.
make: *** [download] Error 1
Done!
Connecting to cable (Usb Port - USB21).Checking cable driver. Driver file xusb_emb.sys found. Driver version: src=1029, dest=1029. Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS12:35:07, version = 811.Cable connection failed.Connecting to cable (Parallel Port - LPT1).Checking cable driver. Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS12:35:07, version = 811. LPT base address = 0378h. ECP base address = FFFFFFFFh.Cable connection failed.Connecting to cable (Parallel Port - LPT2).Checking cable driver. Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS12:35:07, version = 811.Cable connection failed.Connecting to cable (Parallel Port - LPT3).Checking cable driver. Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS12:35:07, version = 811.Cable connection failed.Connecting to cable (Parallel Port - LPT4).Checking cable driver. Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS12:35:07, version = 811.Cable connection failed.Cable autodetection failed. Count ReleaseSemaphore rc = 298.make: *** [download] Error 1Done!
I can't inderstand this please if you have an idea about this issu help me coz I'm really stuck!!
INES
This cable should work with ISE 12.1 and EDK 12.1, but earlier versions have no support for this cable.
