programming wrong *.bin file into FPGA
generally, when FPGA /flash is programmed via JTAG, if a wrong programming file(meant for other FPGA/flash) is chosen, it shows an error msg similar to, "programming file device and actual device does not match".
But when programmed by *.bin fine, through a processor, is there any way to check that? or how to avoid programming a wrong *.bin file into an FPGA ?
Asan.
Tags (2)
a,
The device may only be programmed by a bit file that matches the device (for example 7k325T).  Any other bitfile will result in DONE not going high (device will not be programmed).
Austin Lesea
Principal Engineer
Xilinx San Jose
