project archive not working
I am trying to archive my project in ISE 14.7 but its failing to do so. I am able to archive another project in another directory using same ISE but I don't know why its failing for the one I am using. Please help.
Koyel
Re: project archive not working
Are you getting any error message while archiving?
Anusheel
Helpful answer -> Give Kudos
Anusheel
Are you seeing any error messgae when you trying to archive the project?
Do  you ahve read permissions to the folder in which you are trying to archive?
Please make sure that there won't be any special characters in the directory path in which you are trying to archive the project.
Community Manager
Community Manager
Is this project using any remote sources? Can you try creating a new project with the same sources and see if its getting archived?
Sikta
Hi @koyel81
Are you able to archive the project now?
