Visitor liuhz
refxapp1185. display err,how to resolve it?is license invalid?
11:12:42 **** Build of project BSP_Standalone_ARMCC ****
make -k all
libgen -hw ../ZC702_hw_platform/system.xml\
           -lp D:/XSDK_SPACE/2013.3/BSP_Standalone_ARMCC/ps7_cortexa9_0/libsrc -lp F:/ARM_Res/xapp/XAPP1185/bsp\
           -pe ps7_cortexa9_0 \
           -log libgen.log \
           system.mss
libgen
Xilinx EDK 2013.3 Build EDK_P.20131013
Copyright (c) 1995-2012 Xilinx, Inc.  All rights reserved.
Command Line: libgen -hw ../ZC702_hw_platform/system.xml -lp
F:/ARM_Res/xapp/XAPP1185/bsp -pe ps7_cortexa9_0 -log libgen.log system.mss
Staging source files.
Running DRCs.
Running generate.
Running post_generate.
Running include - 'make -s include "COMPILER=armcc" "ARCHIVER=armar"
"COMPILER_FLAGS= -O2 -c" "EXTRA_COMPILER_FLAGS=-g"'.
License path:  C:\flexlm\license.dat;
FLEXnet Licensing error:-1,359.  System Error: 2 "No such file or directory"
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
make[1]: *** [xttcps_options.o] 错误 1
Error: C9932E: Cannot obtain license for Compiler (feature compiler5) with license version >= 5.0201301
Cannot find license file.
 The license files (or license server system network addresses) attempted are
listed below.  Use LM_LICENSE_FILE to use a different license file,
 or contact your software provider for a license file.
Feature:       compiler5
Filename:      C:\flexlm\license.dat
Cannot obtain license for Compiler (feature bsp_compiler5) with license version >= 5.0201301
Feature:       bsp_compiler5
ARM C/C++ Compiler, 5.03 [Build 24]
make[1]: *** [xttcps_selftest.o] 错误 1
Feature:       compiler5
make[1]: *** [xttcps_sinit.o] 错误 1
make[1]: 由于错误目标“libs”并未重新创建。
"Compiling uartps"
Feature:       compiler5
make[1]: *** [xuartps.o] 错误 1
Feature:       compiler5
make[1]: *** [xuartps_g.o] 错误 1
Feature:       compiler5
make[1]: *** [xuartps_hw.o] 错误 1
Feature:       compiler5
make[1]: *** [xuartps_intr.o] 错误 1
Feature:       compiler5
make[1]: *** [xuartps_options.o] 错误 1
Feature:       compiler5
make[1]: *** [xuartps_selftest.o] 错误 1
Feature:       compiler5
make[1]: *** [xuartps_sinit.o] 错误 1
"Compiling usbps"
Feature:       compiler5
make[1]: *** [xusbps.o] 错误 1
Feature:       compiler5
make[1]: *** [xusbps_endpoint.o] 错误 1
Feature:       compiler5
make[1]: *** [xusbps_g.o] 错误 1
Feature:       compiler5
make[1]: *** [xusbps_hw.o] 错误 1
Feature:       compiler5
make[1]: *** [xusbps_intr.o] 错误 1
Feature:       compiler5
make[1]: *** [xusbps_sinit.o] 错误 1
"Compiling xadcps"
Feature:       compiler5
make[1]: *** [xadcps.o] 错误 1
Feature:       compiler5
make[1]: *** [xadcps_g.o] 错误 1
Feature:       compiler5
make[1]: *** [xadcps_intr.o] 错误 1
Feature:       compiler5
make[1]: *** [xadcps_selftest.o] 错误 1
Feature:       compiler5
make[1]: *** [xadcps_sinit.o] 错误 1
"Compiling cpu_cortexa9"
ERROR:EDK -  make failed for target "libs"
ERROR:EDK - Error(s) while running make.
make: *** [ps7_cortexa9_0/lib/libxil.a] 错误 2
make: 由于错误目标“all”并未重新创建。
11:12:51 Build Finished (took 8s.533ms)
Visitor liuhz
Re: refxapp1185. display err,how to resolve it?is license invalid?
the answer is two version have intalled on one system.when i unstall 2013.2,all is ok.
but the other question is how to migrate xilinx'  ld file to arm' sca file.when i debug in ds, link is connnected,but softeware can not go main function.it looks like main address is not exist.
Are you getting this error in the SDK or in ARM Development Studio 5?
Did you check the full license file path. If you are running SDK then run XINFO on your xilinx command line and send it across as an attachement.
Anirudh
Visitor liuhz
thanks for you reply;
this error displayed in sdk;
i  want to import xilinx driver into ds-5 as the xapp1185 teach,but when i  take the 1st step,when i change the compile option to armcc and armar,the err displayed
Visitor liuhz
the license is download from xilinx.com,for the err infomation,maybe armcc's license  is not valid.
what do you think ?
Yes it looks like the ARM's license is not valid as the xilinx license file ends with xilinx.lic but i find in the error as
C:\flexlm\license.dat.
Please cross check this. Check if the tool is pointing to Xilinx.lic.
However when are you getting this error, when using Xilinx tool or ARM tool?
Anirudh
Are you able to resolve the problem or identiify if it is the licensing problem with SDK or the ARM tool?
Anirudh
Visitor liuhz
maybe  when sdk call armcc, the error display,it seemed that  armcc's version is out of the calling;
the armcc'license in ds-5's is ok;
i execute armcc+sdk'setting  in concole,say mdd file can't find ,
Visitor liuhz
ds-5 version 5.14;
sdk version 2013.3
Visitor liuhz
