reg: map report - blocks/signals optimized while porting from virtex6 to virtex4 ...
hi,
i have a design which i ported on a virtex6 FPGA (xc6vlx240t) which has 6 i/p LUTs.
the lut utilization in the implemented design summary was about 10875 (7% utlization)
in the map report, i see -
8 block(s) removed
2 block(s) optimized away
8 signal(s) removed
i port the same design on a virtex4 FPGA (xc4vlx200) which has 4 i/p LUTs
the lut utilization in the implemented design summary was about 16222 (9% utilization)
24 block(s) removed
368 block(s) optimized away
64 signal(s) removed
im using xilinx ise 14.1
i was wondering why, while porting from virtex6 to virtex4, there is such a large change in the blocks being being optimized/removed in the map reports?
any clues/ideas?
z.
moving to xilinx implementation thread ...
z.
