requirement of dynamicly reconfigueration
Is it possible to dynamicly reconfigure logic rather than source like pll or gtx. In the other world,what the limit about dynamic reconfiguration
Re: requirement of dynamicly reconfigueration
No, you cannot use DRP for changing user logic.
Dynamic reconfiguration is done using the DRP primtive which gains access to the Registers related to the HARD BLOCKS in the FPGA like DCM,MMCM, GT etc.
However one option in case you want to change User Logic intermittently, then you can do Partial reoncifugarion of certain block in your code which you want to replace with a different code and implementation.
Anirudh
PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.
please elaborate little more on your post
http://forums.xilinx.com/xlnx/board/crawl_message?board.id=NewUser&message.id=7717
here is few good read on this topic
www.xilinx.com/support/documentation/application_notes/xapp879.pdf
www.xilinx.com/support/documentation/application_notes/xapp888_7Series_DynamicRecon.pdf
Thanks and Regards
Balkrishan
Anirudh
thanks a lot
