restrictions on using posedge Vs negedge on xilinx FPGAs ..
hi,
i am able to implement my designs using both posedge and negedge. however, is there any restriction that only posedge should be used on FPGAs?
i am targetting virtex6 vlx760 devices (ISE14.1).
i ask because long back i vaguely remember reading somewhere that "certain FPGAs only support posedge logic". is it true for any older xilinx FPGA family type?
any restricstion i need to keep in mind while using the negedge for my logic?
help refresh :)
z.
Tags (3)
Teacher muzaffer
Re: restrictions on using posedge Vs negedge on xilinx FPGAs ..
as long as you don't use them in the same event expression, you are OK. I don't know of any Xilinx FPGAs which only support posedge. One thing you need to pay attention is that a mixed edge system has half the period available for timing so meeting timing would be more difficult.
