send raw video data from axi4 stream over ethernet
hello,
i want to send raw uncompressed video data from axi4 stream over ethernet to pc. I plan to send single images in byte arrays and indication of picture size using udp/ip. Do i have to convert the data from axi4 stream bevor i can send it in ip packets? Can you give me some hints what ethernet ip core (i would be glad if there exists a free one) is recommended for this application? Are there any ip cores i can use to transform the data if necessary? (to yet i read many app notes and guides...)
thanks, mrb
Re: send raw video data from axi4 stream over ethernet
I think you may want to look into this:
http://www.xilinx.com/publications/prod_mktg/CS1033_BroadcastVOIP_ProdBrf_FINAL.pdf
I haven't actually used it myself, but this may be what you are looking for. It does use SMPTE layer, and uses UDP as transport layer. I don't know what this IP comes with, but if it comes with some sort of API that takes care of all the IP/UDP overhead, then that is probably what you need.
Here some information about the SMPTE layer:
http://tech.ebu.ch/docs/techreview/trev_2012-Q4_SDI-over-IP_Laabs.pdf
--Rudy
