storing .txt file in an array..
hi all !
i have made a program to read a text file from a specified location , and i want to store it an array .. i don't know how to do this...please help me..
here is my code for reading a file..
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
use STD.textio.all;
ENTITY read_file IS
END read_file;
ARCHITECTURE beha OF read_file IS
    signal  bin_value : std_logic_vector(3 downto 0):="0000";
BEGIN
   --Read process
    process
      file file_pointer : text;
        variable line_content : string(1 to 4);
      variable line_num : line;
        variable j : integer := 0;
        variable char : character:='0';
   begin
      file_open(file_pointer,"C:\read.txt",READ_MODE);
      while not endfile(file_pointer) loop
      readline (file_pointer,line_num);
      READ (line_num,line_content);
        for j in 1 to 4 loop
            char := line_content(j);
            if(char = '0') then
                bin_value(4-j) <= '0';
            else
                bin_value(4-j) <= '1';
            end if;
        end loop;
        wait for 10 ns;
      end loop;
      file_close(file_pointer);
        wait;
    end process;
end beha;
Re: storing .txt file in an array..
Is what you are trying to do is send a text file from the hard-disk of your PC to an FPGA on some sort of development board that is connected to the PC by some sort of interface?
"If it don't work in simulation, it won't work on the board."
i want to take the contents from that file store it in an array and see the reult of stored data in the simulation window.
So, what doesn't work with the above code when you simulate it?
