timing summary show very low frequency
I found that the Maximum frequency of my project is quite low. I generated TriMac and MIG core by Core Generator and merge the ucf files from their example designs as a ucf file of my design.  I have test my design on board, it works well.
I also check the example design of Trimac, the timing summary also show its maximum frequency is around 7MHz.
My ucf file is enclosed, could you please check it?
Timing summary:
Timing errors: 0 Score: 0 (Setup/Max: 0, Hold: 0)
Constraints cover 391019 paths, 0 nets, and 149724 connections
Design statistics:
Minimum period: 194.040ns{1} (Maximum frequency: 5.154MHz)
Maximum path delay from/to any node: 7.599ns
Minimum input required time before clock: 1.298ns
Teacher muzaffer
Re: timing summary show very low frequency
this is probably not about your constraints but about your design. Post your worst case timing path so that someone can comment on how to make it faster.
回复: timing summary show very low frequency
The project is compiled by ISE 14.6
Teacher muzaffer
