Newbie hungpotter9
using ISE 11
I am writing a program using state machine and component. I have an error and i do not understand. This is : ERROR:HDLParsers:164 - "C:/Documents and Settings/ex1/project/main_project.vhd" Line 104. parse error, unexpected PORT, expecting OPENPAR or TICK or LSQBRACK. Could you explain for me ?
Professor
Professor
Re: using ISE 11
This very illuminating message usually occurs when you have a simple syntax error
like leaving out a semicolon or forgetting to close a parenthesis.  The error is either
in the line mentioned (104) or more likely on the preceding line.  If you post a bit of your
code someone might be able to help further.
The message itself indicates that the PORT keyword was found when it was
expecting a left parenthesis, apostrophe, or left square bracket character "(", "'" or "["
regards,
Gabor
-- Gabor
Re: using ISE 11
I would also recommend you move your project to a directory with no spaces in the path.
Not an official answer, but a practice I started a long time ago before I worked here and have seen prove beneficial many times.
They've tried to escape these properly (a space is traditionally a command line separator for the tool arguement), but there are a lot of tools and usage models.
There are likely still a few corner cases where this can cause issues.
Just a friendly unofficial suggestion...
bt
