anee_anil
vhdl code help
Hi all,
I have to send  1 D array  at each  rising edge of the clk. below is my code please help me to complete the code.
entity data_sense is
port(       clk : in std_logic;
             --addr : in integer range 0 to 3;
         data_out : out std_logic_vector(15 downto 0));
end data_sense;
architecture Behavioral of data_sense is
type vector_array is array(0 to 3) of std_logic_vector(15 downto 0);
signal memory : vector_array;
signal addr  : integer range 0 to 3;
--type vector_array1 is array(0 to 3) of std_logic_vector(15 downto 0);
--signal temp : vector_array1;
signal temp : std_logic_vector(15 downto 0);
begin
memory(0)(15 downto 0) <= "1111000011110000";
memory(1)(15 downto 0) <= "1111000011110000";
memory(2)(15 downto 0) <= "0111000011110000";
memory(3)(15 downto 0) <= "1111000011110000";
process(clk)
--variable temp : std_logic_vector(15 downto 0);
begin
for i in 0 to 3 loop
if(clk'event and clk = '1') then
temp <= memory(i)(15 downto 0);
end if;
end loop;
end process;
data_out <= temp;
end Behavioral;
I have to send 4 array one by one repeatedly at all the rising edge of the clk :)
Please help.
sridar
You can use ROM based approach for this.
 Example code is below
entity romapproach is
    Port ( clk : in  STD_LOGIC;
          dout : out  STD_LOGIC_VECTOR (15 downto 0));
end romapproach
architecture Behavioral of romapproach is
 type data is array (0 to 3) of std_logic_vector (15 downto 0);
 Signal SData : data:=  (  "1111000011110000","1111000011110000","0111000011110000","1111000011110000");
 Signal dcount : integer range 0 to 3;
begin
Process (clk)
begin
If rising_edge (clk) then
   dout <= Sdata(dcount);
 if (dcount = 3) then
  dcount <= 0;
  else dcount <= dcount+1;
  end if;
end if;
end process;
end Behavioral;
FPGA freak
sridar
end romapproach
begin
Process (clk)
begin
  dcount <= 0;
  end if;
end if;
end process;
end Behavioral;
FPGA freak
anee_anil
Thanks sridar,
The code is working as i expected :)
with regards
ANIL
