virtex 6 partial reconfiguration
divice:virtex 6 vlx240t
ISE:14.5
PlanAhead:14.5
In my project, generate MIG controller CORE that is static module and partial module is LED flash,;so the static ngc is top.ngc  and the partial ngc is led.ngc;  I learn to ug702.pdf and flow the design; when I select Open Synthesized Design,the tool PlanAhead 14.5 is closed; I try many times and always the same;  the warning : Abnormal program termination <EXCEPTION_ACCES_VIOLATION>;
I think about the assign IP restrictions may occure due to components used to implement the IP .Examples include :ChipScope ICON  ,  EDK blocks ,  MIG controller(MMCM)  in  the ug702.pdf page 17.
is that mean MIG core can't be used in partial reconfiguration project?
I already try many ways and failed.
who can suggest some ideas and help me ?
Re: virtex 6 partial reconfiguration
This looks like a crash. I would recommend to this in Planahead 14.7.
There are no restrictions with respect to MIG.Hope this helps.
Sikta
