Advisor
Advisor
4x4 matrix inversion?
Hello Guys,
I need to do a 4x4 matrix inversion for MIMO style antenna combining.  Matrix inversion can be very sensitive to underflow and loss of significance so I thought I would try using a floating point implementation via HLS.  I have code that compiles in Vivado HLS and gives correct simulation results but the logic really blows up.  It seems to be implementing all the 4x4=16 numbers in parallel.
My code is written that way, 16 equations for the 16 entries of the inverted matrix, so I am not surprised but I would really like to get logic that implements one adder and one multiplier and then sequences the data through them.  It is ok if the calculation requires hundreds of clock cycles.  These inversions are done at a low rate.
Can anyone recommend compiler directives that will cause HLS to serialize the calculations?
I attach my code in case you are interested.
Thanks in advance.
  Pete Dudley
DSP in hardware and software
Hello Pete,
If you'd have a loop somewhere, i may be easier for the tool.
Anyway, here you need a directive allocation - check UG902 or help set_directive_allocation to pickup the right core, you may need to check what is used from the names of the instances.
What (I reckon) you will end up with is a FSM that will sequence N set of data through your FP cores via MUXes. The FSM will have N+something states.
Let us know which directives you end-up using...
good luck!
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
Yes seeing the code would help.
Try UNROLL directive on the loop to see if it helps.
Debraj
Advisor
Advisor
Sorry,
Here is the code for the 4x4 matrix inverter.
bool
mat_inv_4x4(float m[16], float inv[16])
float  det;
int i;
    inv[0] = m[5]  * m[10] * m[15] -
             m[5]  * m[11] * m[14] -
             m[9]  * m[6]  * m[15] +
             m[9]  * m[7]  * m[14] +
             m[13] * m[6]  * m[11] -
             m[13] * m[7]  * m[10];
inv[4] = -m[4] * m[10] * m[15] +
              m[4]  * m[11] * m[14] +
              m[8]  * m[6]  * m[15] -
              m[8]  * m[7]  * m[14] -
              m[12] * m[6]  * m[11] +
              m[12] * m[7]  * m[10];
    inv[8] = m[4]  * m[9] * m[15] -
             m[4]  * m[11] * m[13] -
             m[8]  * m[5] * m[15] +
             m[8]  * m[7] * m[13] +
             m[12] * m[5] * m[11] -
             m[12] * m[7] * m[9];
    inv[12] = -m[4]  * m[9] * m[14] +
m[4] * m[10] * m[13] +
               m[8]  * m[5] * m[14] -
               m[8]  * m[6] * m[13] -
               m[12] * m[5] * m[10] +
               m[12] * m[6] * m[9];
    inv[1] = -m[1]  * m[10] * m[15] +
              m[1]  * m[11] * m[14] +
              m[9]  * m[2] * m[15] -
              m[9]  * m[3] * m[14] -
              m[13] * m[2] * m[11] +
              m[13] * m[3] * m[10];
    inv[5] = m[0]  * m[10] * m[15] -
             m[0]  * m[11] * m[14] -
             m[8]  * m[2] * m[15] +
             m[8]  * m[3] * m[14] +
             m[12] * m[2] * m[11] -
             m[12] * m[3] * m[10];
    inv[9] = -m[0]  * m[9] * m[15] +
              m[0]  * m[11] * m[13] +
              m[8]  * m[1] * m[15] -
              m[8]  * m[3] * m[13] -
              m[12] * m[1] * m[11] +
              m[12] * m[3] * m[9];
    inv[13] = m[0]  * m[9] * m[14] -
              m[0]  * m[10] * m[13] -
              m[8]  * m[1] * m[14] +
              m[8]  * m[2] * m[13] +
              m[12] * m[1] * m[10] -
              m[12] * m[2] * m[9];
    inv[2] = m[1]  * m[6] * m[15] -
             m[1]  * m[7] * m[14] -
             m[5]  * m[2] * m[15] +
             m[5]  * m[3] * m[14] +
             m[13] * m[2] * m[7] -
             m[13] * m[3] * m[6];
    inv[6] = -m[0]  * m[6] * m[15] +
              m[0]  * m[7] * m[14] +
              m[4]  * m[2] * m[15] -
              m[4]  * m[3] * m[14] -
              m[12] * m[2] * m[7] +
              m[12] * m[3] * m[6];
    inv[10] = m[0]  * m[5] * m[15] -
              m[0]  * m[7] * m[13] -
              m[4]  * m[1] * m[15] +
              m[4]  * m[3] * m[13] +
              m[12] * m[1] * m[7] -
              m[12] * m[3] * m[5];
    inv[14] = -m[0]  * m[5] * m[14] +
               m[0]  * m[6] * m[13] +
               m[4]  * m[1] * m[14] -
               m[4]  * m[2] * m[13] -
               m[12] * m[1] * m[6] +
               m[12] * m[2] * m[5];
    inv[3] = -m[1] * m[6] * m[11] +
              m[1] * m[7] * m[10] +
              m[5] * m[2] * m[11] -
              m[5] * m[3] * m[10] -
              m[9] * m[2] * m[7] +
              m[9] * m[3] * m[6];
    inv[7] = m[0] * m[6] * m[11] -
             m[0] * m[7] * m[10] -
             m[4] * m[2] * m[11] +
             m[4] * m[3] * m[10] +
             m[8] * m[2] * m[7] -
             m[8] * m[3] * m[6];
    inv[11] = -m[0] * m[5] * m[11] +
               m[0] * m[7] * m[9] +
               m[4] * m[1] * m[11] -
               m[4] * m[3] * m[9] -
               m[8] * m[1] * m[7] +
               m[8] * m[3] * m[5];
    inv[15] = m[0] * m[5] * m[10] -
              m[0] * m[6] * m[9] -
              m[4] * m[1] * m[10] +
              m[4] * m[2] * m[9] +
              m[8] * m[1] * m[6] -
              m[8] * m[2] * m[5];
    det = m[0] * inv[0] + m[1] * inv[4] + m[2] * inv[8] + m[3] * inv[12];
if (det == 0)
returnfalse;
    det = 1.0 / det;
    det_for:
for (i = 0; i < 16; i++)
        inv[i] = inv[i] * det;
returntrue;
Hello Pete,
good luck!
- Hervé
SIGNATURE:
Advisor
Advisor
Hervé
I decided that HLS can unroll loops but it cannot take un-looped code and deduce hardware re-use.
Looking at the code above there is a lot of regularity.  The 16 equations each require 6 multiplies so I created a table of pointers to the input data and put the multiplies inside several loops.  This resulted in very compact logic but still written C++.
My conclusion is that, even with HLS, you need to keep in mind what logic you want implemented and organize your code that way.
Thanks for the help and encouragement.
  Pete
Thanks Pete for your feedback!
I guess that's a fair comment - and feedback to other users.
Thinking more about it, the original code has 12 multipliers for each of the 16 inv[] which would probably look like a "complex" spaghetti problem so the tools may try to schedule all of them initially, then followed by the adders etc.
The structured loop code is giving strongs hints about what to do for a fairly easier problem.
- Hervé
SIGNATURE:
