A problem of using HLS
I have some code:
void subBytes_shiftRows(uint8_t input[16], uint8_t output[16])
lookup_sbox(input[0] , &output[0] );
lookup_sbox(input[5] , &output[1] );
lookup_sbox(input[10], &output[2] );
lookup_sbox(input[15], &output[3] );
lookup_sbox(input[4] , &output[4] );
lookup_sbox(input[9] , &output[5] );
lookup_sbox(input[14], &output[6] );
lookup_sbox(input[3] , &output[7] );
lookup_sbox(input[8] , &output[8] );
lookup_sbox(input[13], &output[9] );
lookup_sbox(input[2] , &output[10]);
lookup_sbox(input[7] , &output[11]);
lookup_sbox(input[12], &output[12]);
lookup_sbox(input[1 ], &output[13]);
lookup_sbox(input[6 ], &output[14]);
lookup_sbox(input[11], &output[15]);
void lookup_sbox(uint8_t sbox_in, uint8_t *sbox_out)
static uint8_t sbox[256] = {
0x63, 0x7c, 0x77, 0x7b, 0xf2, 0x6b, 0x6f, 0xc5,
0x30, 0x01, 0x67, 0x2b, 0xfe, 0xd7, 0xab, 0x76,
0xca, 0x82, 0xc9, 0x7d, 0xfa, 0x59, 0x47, 0xf0,
0xad, 0xd4, 0xa2, 0xaf, 0x9c, 0xa4, 0x72, 0xc0,
0xb7, 0xfd, 0x93, 0x26, 0x36, 0x3f, 0xf7, 0xcc,
0x34, 0xa5, 0xe5, 0xf1, 0x71, 0xd8, 0x31, 0x15,
0x04, 0xc7, 0x23, 0xc3, 0x18, 0x96, 0x05, 0x9a,
0x07, 0x12, 0x80, 0xe2, 0xeb, 0x27, 0xb2, 0x75,
0x09, 0x83, 0x2c, 0x1a, 0x1b, 0x6e, 0x5a, 0xa0,
0x52, 0x3b, 0xd6, 0xb3, 0x29, 0xe3, 0x2f, 0x84,
0x53, 0xd1, 0x00, 0xed, 0x20, 0xfc, 0xb1, 0x5b,
0x6a, 0xcb, 0xbe, 0x39, 0x4a, 0x4c, 0x58, 0xcf,
0xd0, 0xef, 0xaa, 0xfb, 0x43, 0x4d, 0x33, 0x85,
0x45, 0xf9, 0x02, 0x7f, 0x50, 0x3c, 0x9f, 0xa8,
0x51, 0xa3, 0x40, 0x8f, 0x92, 0x9d, 0x38, 0xf5,
0xbc, 0xb6, 0xda, 0x21, 0x10, 0xff, 0xf3, 0xd2,
0xcd, 0x0c, 0x13, 0xec, 0x5f, 0x97, 0x44, 0x17,
0xc4, 0xa7, 0x7e, 0x3d, 0x64, 0x5d, 0x19, 0x73,
0x60, 0x81, 0x4f, 0xdc, 0x22, 0x2a, 0x90, 0x88,
0x46, 0xee, 0xb8, 0x14, 0xde, 0x5e, 0x0b, 0xdb,
0xe0, 0x32, 0x3a, 0x0a, 0x49, 0x06, 0x24, 0x5c,
0xc2, 0xd3, 0xac, 0x62, 0x91, 0x95, 0xe4, 0x79,
0xe7, 0xc8, 0x37, 0x6d, 0x8d, 0xd5, 0x4e, 0xa9,
0x6c, 0x56, 0xf4, 0xea, 0x65, 0x7a, 0xae, 0x08,
0xba, 0x78, 0x25, 0x2e, 0x1c, 0xa6, 0xb4, 0xc6,
0xe8, 0xdd, 0x74, 0x1f, 0x4b, 0xbd, 0x8b, 0x8a,
0x70, 0x3e, 0xb5, 0x66, 0x48, 0x03, 0xf6, 0x0e,
0x61, 0x35, 0x57, 0xb9, 0x86, 0xc1, 0x1d, 0x9e,
0xe1, 0xf8, 0x98, 0x11, 0x69, 0xd9, 0x8e, 0x94,
0x9b, 0x1e, 0x87, 0xe9, 0xce, 0x55, 0x28, 0xdf,
0x8c, 0xa1, 0x89, 0x0d, 0xbf, 0xe6, 0x42, 0x68,
0x41, 0x99, 0x2d, 0x0f, 0xb0, 0x54, 0xbb, 0x16
*sbox_out = (uint8_t) sbox[sbox_in];
I have reshaped the input and output of function subBytes_shiftRows, I hope I can read 128bits data at one time, there are16 lookup_sbox modules,we can get the output in 3 clock cycles. But it is optimized automatically, there is only one lookup_sbox module, what can I do to generate what I wante?
Have you tried this?
#include "ap_cint.h"
void subBytes_shiftRows(uint8 input[16], uint8 output[16])
#pragma HLS ARRAY_RESHAPE variable=input complete dim=1
#pragma HLS ARRAY_RESHAPE variable=output complete dim=1
void lookup_sbox(uint8 sbox_in, uint8 *sbox_out)
#pragma HLS PIPELINE
static uint8 sbox[256] = {
#pragma HLS ARRAY_PARTITION variable=sbox complete dim=1
As far as I can see, this generates 16 lookup_sbox instances, with "some" LUTs in order to execute in 1 cycle. Adjust the directives in order to fit to your needs.
begin
    call_ret1_lookup_sbox_fu_88 : component lookup_sbox
    port map (
        sbox_in => call_ret1_lookup_sbox_fu_88_sbox_in,
        ap_return => call_ret1_lookup_sbox_fu_88_ap_return);
    call_ret2_lookup_sbox_fu_93 : component lookup_sbox
    port map (
        sbox_in => call_ret2_lookup_sbox_fu_93_sbox_in,
        ap_return => call_ret2_lookup_sbox_fu_93_ap_return);
    call_ret3_lookup_sbox_fu_98 : component lookup_sbox
    port map (
        sbox_in => call_ret3_lookup_sbox_fu_98_sbox_in,
        ap_return => call_ret3_lookup_sbox_fu_98_ap_return);
    call_ret4_lookup_sbox_fu_103 : component lookup_sbox
    port map (
Please let us know if the suggestion was helpful? If its fixed already we can close this post as an Accepted Solution for future usage. If you have found an alternate solution, kindly post it too for others.
Debraj
