araongao2015
A question about reading data from an external file
Could you check the C++ source code below? If the stimulus and sti_val are declared as int, this code can work well. By contrast,
if they are declared as ap_int<8>, error occurs. It will generate critical warning like below:
CRITICAL WARNING: [SIM 1] 'csim_design' failed: nonzero return value.
I use Vivado HLS 2016.1.
My question is whether Vivado HLS 2016.1 can support read data from external file for ap_int or ap_fixed data.
#include <iostream>
#include <iomanip>
#include <fstream>
#include <ap_int.h>
using namespace std;
int main ()
  int stimulus[4] = {0};
  int sti_val;
  char *stimulus_source = "a.txt";
  ifstream sti (stimulus_source);
  int i = 0;
  if (!sti.is_open())
    cout << "The file is unable to open!" << '\n';
    return 1;
  else
    while (sti >> sti_val)
      cout << "The current value of i: " << i << '\n';
      stimulus[i] = sti_val;
      i++;
  sti.close();
  for (i = 0; i < 4; i++)
    cout << "The ith value of stimulus is: " << stimulus[i] << '\n';
  return 0;
u4223374
Advisor
Advisor
I normally use the standard "C" functions (ie fread/fwrite, fscanf/fprintf) and those are not happy with the ap_int types. Better to read things in using regular ints and cast them across later. In your case, something like this might work:
#include <iostream>
#include <iomanip>
#include <fstream>
#include <ap_int.h>
#include <stdint.h>
int main ()
  ap_uint<8> stimulus[4] = {0};
  int32_t sti_val;
  int i = 0;
  if (!sti.is_open())
    return 1;
  else
    while (sti >> sti_val) // sti_val is now a normal integer, so it'll be fine.
      stimulus[i] = sti_val; // Conversion to ap_int<8> occurs automatically; you may want to check bounds.
      i++;
  sti.close();
    cout << "The ith value of stimulus is: " << int32_t(stimulus[i]) << '\n'; // Explicitly cast it to an int32_t.
  return 0;
araongao2015
Hi @u4223374,
Thank you. Yes, it can work. But if the data type is ap_int<72>, this means it cannot be indicated by normal int. In this case, what should I do? Bye the way, I try to define a float variable to receive data from external file and convert it ap_int. Do you have any other more effective method?
From this point of view, I don't think Vivado HLS support reading file efficiently and effectively.
araongao2015
It is surprising that if the data type is ap_fixed, this error will not occur.
