Participant gustavsvj
AXI Stream to Memory
I'm fairly new to HLS development so hopefully this is a fairly simple qustion.
I have a 64 bit wide input AXI stream and a 512 bit wide DDR4 interface both running at 300MHz. The goal is to store the data arriving on the stream to the DDR4 memory.
This functionality is actually working but I'm unhappy with the achieved transfer speed. The current code is structured in the following three functions:
  1. Buffer around 1KB of data
  2. Calculate memory address
  3. Write to memory using memcpy
These are currently executed sequential when looking at both the analysis and the co simulation results. This means that the input stream is blocked while the data is written to memory which I would really like to avoid.
In RTL I would implement this using two buffers that could be written to/read from alternately. How can I achieve something similar (or better) in HSL?
Kind regards,
Gustav
Tags (3)
Re: AXI Stream to Memory
Hello @gustavsvj
The 65% utilization that you quote I'm guessing it's coming from :
1- the top function II=294 versus
2- the trip count that you get in your read data function: 24 outer loops and 8 inner loops => II should be close to 24*8=192
so 192/294 = 65 % utilization.
I'm sure you see the answer now: you need to get the II of read data function closer to the ideal value rather than the what you have now.. ie one way or another, and/or depending on your coding style preference, you need to hoist the pipeline in the outer loop or manually merge the 2 loops.
something like this... please check with your C TB if this is still correct
void readData(AXI_STREAM &s_axis_data, ap_uint<512> *data, ap_uint<16> *size){
    ap_uint<512> buff;
    AXI_T dataIn;
readloop:
    for (int xx = 0; xx < 24*8; xx++) {
        #pragma HLS PIPELINE II=1
        dataIn = s_axis_data.read();
        int j = xx / 8;
        ap_uint<3> i = xx;
        switch(i){
            // on first iteration, you store and clear all of buff
            case 0: buff = dataIn.data; break;
            case 1: buff(127,64) = dataIn.data; break;
            case 2: buff(191,128) = dataIn.data; break;
            case 3: buff(255,192) = dataIn.data; break;
            case 4: buff(319,256) = dataIn.data; break;
            case 5: buff(383,320) = dataIn.data; break;
            case 6: buff(447,384) = dataIn.data; break;
            case 7: buff(511,448) = dataIn.data; break;
        data[j] = buff;
        if (dataIn.last){
//            *size = (i + 1) * sizeof(ap_uint<64>) + j * 64;
//            don't do sizeof on classes!!
// would have been better to have constants in the header *size = (i + 1) * 8 + (j) * 64; break; } } // readloop }
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
Did you try applying DATAFLOW ?
Nithin
Dear Nithin,
I did try that. Unfortunately it doesn't have an effect. I'm guessing it's because the data buffer is used both when reading and writing data.
Kind regards,
Gustav
Hi Gustav,
  Can you share your code.
Nithin
memory_writer.cpp:
#include "memory_writer.hpp"
#include <hls_stream.h>
#include <ap_axi_sdata.h>
#include <ap_int.h>
#include <string.h>
	void performWrite(ap_uint<512> *ddr, ap_uint<512> *data, ap_uint<32> address, ap_uint<16> size){
		memcpy(ddr + address, data, size);
		for (ap_uint<8> j = 0; j < 24; j++){
			ap_uint<512> buff;
			AXI_T dataIn;
			for (ap_uint<4> i = 0; i < 8; i++){
				switch(i % 8){
				case 0:
					buff(63,0) = dataIn.data;
					break;
				case 1:
					break;
				case 2:
					break;
				case 3:
					break;
				case 4:
					break;
				case 5:
					break;
				case 6:
					break;
				case 7:
					break;
				if (dataIn.last){
					break;
			data[j] = buff;
			if (dataIn.last){
				break;
	void addrCounter(ap_uint<32> *addr, ap_uint<16> size){
		static ap_uint<32> addrBuff = 0;
		static ap_uint<16> eventCount = 0;
		eventCount++;
		if (eventCount > 1024){
			*addr = 0;
			addrBuff = 0;
			eventCount = 0;
		else{
			*addr = addrBuff;
			if (size % 64 != 0){
				addrBuff += (size / 64) + 1;
			else{
				addrBuff += (size / 64);
void memory_writer(AXI_STREAM &s_axis_data, ap_uint<512> *ddr){
#pragma HLS INTERFACE ap_ctrl_none port=return
#pragma HLS INTERFACE m_axi port=ddr depth=1000 offset=none
#pragma HLS INTERFACE axis port=s_axis_data
#pragma HLS dataflow
	ap_uint<512> dataBuff[24];
	ap_uint<16> dataSize;
	ap_uint<32> addr;
	readData(s_axis_data, dataBuff, &dataSize);
	addrCounter(&addr, dataSize);
	performWrite(ddr, dataBuff, addr, dataSize);
memory writer.hpp:
#include <ap_int.h>
#define MAX_PKG_SIZE 1400
#define MEM_DEPTH (1400 * 8 * 1024) / 512
typedef ap_axiu <64,0,0,0> AXI_T;
typedef hls::stream<AXI_T> AXI_STREAM;
void memory_writer(AXI_STREAM &s_axis_data, ap_uint<512> *ddr);
Hi Gustav,
  I see that DATAFLOW does have an effect.
If you remove data flow and run, you can see that the total latency is the sum of latencies from each of the functions. while with data flow, it's much less
Nithin
Dear Nithin,
You're of course right. What I meant was that it doesn't have enough of an effect.
With DATAFLOW enabled I get around 65% of utilization on the input stream when testing the code on the KCU105. When looking at the data widths it should be possible to get a 100% utilization of the input stream as the output has around 8 times the bandwidth.
So my qustion is how I should structere my HLS code so the buffering operation can run in parallel with the write operation?
Kind regards,
Gustav
Hello @gustavsvj
    ap_uint<512> buff;
    AXI_T dataIn;
readloop:
        int j = xx / 8;
        ap_uint<3> i = xx;
        switch(i){
        data[j] = buff;
        if (dataIn.last){
- Hervé
SIGNATURE:
Dear Hervé
You're a hero! Your observation is totally accurate.
With your improvements the code is providing very close to a 100% of the bandwidth.
Thank you very much!
Kind regards,
Gustav
