AXI video stream with dynamic rows
I am creating a passthrough HLS IP. In the below code, if the number of columns changes (by modifying the x_max and x_min), it works. However, if I change the row value, the IP hangs. So, for this IP, I have to make the output stream has the same rows as the input. I guess the problem is at the Start of Frame signal but could not understand why. Could you please help me on this?
void ip_accel_app(hls::stream< ap_axiu<48,1,1,1> >& _src,hls::stream< ap_axiu<48,1,1,1> >& _dst)
#pragma HLS INTERFACE axis register both  port=_src
#pragma HLS INTERFACE axis register both  port=_dst
#pragma HLS INTERFACE ap_ctrl_none port=return
	ap_axiu<48, 1, 1, 1> _tempStream;
	int indexSrcMat = 0;
	int res = 0, depth;
	xf::Mat<TYPE, HEIGHT, WIDTH, NPC1> imgInput1(HEIGHT, WIDTH);
	xf::Scalar<XF_CHANNELS(TYPE, NPC1), XF_TNAME(TYPE,NPC1)> temppixel;
	int nSrc_rows = HEIGHT;
	int nSrc_cols = WIDTH/NPC1;
	int i, j;
	int nDst_rows =0;
	int nDst_cols =0;
	bool sof = 1;
	indexSrcMat = 0;
#pragma HLS stream variable=imgInput1.data dim=1 depth=1
#pragma HLS dataflow
	xf::AXIvideo2xfMat(_src, imgInput1);
	loop_height: for (i = 0; i < HEIGHT; i++)
		loop_width: for (j = 0; j < WIDTH / NPC1; j++) {
		#pragma HLS loop_flatten off
		#pragma HLS pipeline II=1
			//read pixel
			fillingdata(imgInput1, temppixel,indexSrcMat);
			indexSrcMat++;
			if((i>=roi_y_min)&&(i<roi_y_max)&&(j>=roi_x_min)&&(j<roi_x_max))//is in ROI?
				if(sof)//start of frame
					_tempStream.user = 1;
					sof = 0;
				else
					_tempStream.user = 0;
				if(j==roi_x_max-1)//is end of line
					_tempStream.last =1;
				else
					_tempStream.last =0;
				_tempStream.data = -1;
				xf::AXISetBitFields(_tempStream, 0, 48, temppixel.val[0]);
				_tempStream.keep = -1;
				_dst << _tempStream;
