Accessing of "Xilinx Model Composer"
Hi Xilinx,
Can you please let me know how to access Intall and access Xilinx Model Composer, am not to access in any way, Kindly let me know
Sandeep.
Hi @ssundur ,
Have you visit the Model Composer Web to purchase a license?
https://www.xilinx.com/products/design-tools/vivado/integration/model-composer.html#buy
User Guide
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug973-vivado-release-notes-install-license.pdf
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug1262-model-composer-user-guide.pdf
Tutorial
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug1259-model-composer-tutorial.pdf
Wen
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Hi @ssundur
This is the same installer as per vivado/vitis (unified installer):
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2020-1.html
During the installation, when selecting the elements, expend vitis and you will see Model composer under it
Florent
