@datang
Active time of sub-function when it runs on FPGA
I suppose I have function top. Inside top function, I call sub-function A. I want to determine active time of sub-function A(when function A starts, when it stops)  when function top run on FPGA. what should I do with HLS code?
baltam
@datang wrote:
But ap_start and ap_done are only generated for function top, and function A doesnt have any signal as ap_done, ap_start.
Not true. It depends on how you have defined the interface of A.
Please look at the following code snips.
The following C source comes from a real project where the interface protocol is the default one ap_ctrl_hs (_hs here means 'hand-shaking').
The TOP function is RunMMTOneSL() , the inner function  is RunMMTOneMC()
#include...
// TOP HLS function
void RunMMTOneSL( WireShift_t corrFirstWire, .... )
    #pragma HLS ARRAY_PARTITION ....
    for ( MCellIdx_t iMacroCell = 0; iMacroCell < MAX_MACROCELLS; ++iMacroCell )
      #pragma HLS UNROLL
      timePMCell[ iMacroCell ] = RunMMTOneMC( cntHits[ iMacroCell ], .... );
// Inner function
TimeTDC_t RunMMTOneMC( b5_Idx_t cntHits,.... )
 ...<body of function> ...
This has been mapped in VHDL  by HLS as follow
-- RTL generated by Vivado(TM) HLS - High-Level Synthesis from C, C++ and SystemC
-- Version: 2016.1
-- Copyright (C) 1986-2016 Xilinx, Inc. All Rights Reserved.
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity RunMMTOneSL is
port (
    ap_clk : IN STD_LOGIC;
    ap_rst : IN STD_LOGIC;
    ap_start : IN STD_LOGIC;
    ap_done : OUT STD_LOGIC;
    ap_idle : OUT STD_LOGIC;
    ap_ready : OUT STD_LOGIC;
    corrFirstWire_V : IN STD_LOGIC_VECTOR (2 downto 0);
end;
architecture behav of RunMMTOneSL is
    attribute CORE_GENERATION_INFO : STRING;
    attribute CORE_GENERATION_INFO of behav : architecture is
component RunMMTOneSL_RunMMTOneMC IS port ( ap_clk : IN STD_LOGIC; ap_rst : IN STD_LOGIC; ap_start : IN STD_LOGIC; ap_done : OUT STD_LOGIC; ap_idle : OUT STD_LOGIC; ap_ready : OUT STD_LOGIC; cntHits_V : IN STD_LOGIC_VECTOR (4 downto 0); ... ); end component; begin grp_RunMMTOneSL_RunMMTOneMC_fu_1614 : component RunMMTOneSL_RunMMTOneMC port map ( ap_clk => ap_clk, ap_rst => ap_rst, ap_start => grp_RunMMTOneSL_RunMMTOneMC_fu_1614_ap_start, ap_done => grp_RunMMTOneSL_RunMMTOneMC_fu_1614_ap_done, ap_idle => grp_RunMMTOneSL_RunMMTOneMC_fu_1614_ap_idle, ap_ready => grp_RunMMTOneSL_RunMMTOneMC_fu_1614_ap_ready, cntHits_V => cntHits_0_V, .... ); ....
.... end behav;
As fast check you could try to change the block-level I/O protocol of function A and check the interface summary on synthesis report.
u4223374
Advisor
Advisor
HLS can tell you this in the synthesis report.
If you actually want to measure it at runtime, that's going to be tricky - time to connect a debug core and start digging through the HDL code.
@datang
I know HLS can report about latency of function top. when function A access to DDRAM, report about latency of function A is incorrect. I want to know when function A starts, when it stops.
I read HDL code which is generated by HLS, and it has many states, so I dont know where function A starts to tricky - time.
with HSL code, what can I do?
baltam
@datang wrote:
... I want to know when function A starts, when it stops.
In simulation, if the block-level handshakes of the function A is enabled or you can enable it, then you should be able to measure the elapsed time between ap_start and ap_done signals. If you want to measure them in a real system with a scope, you have to add 2 signals to the TOP I/O interface and active them at the beginning and at the end of the A function.
@datang
baltam
#include...
// TOP HLS function
      #pragma HLS UNROLL
// Inner function
-- Version: 2016.1
library IEEE;
port (
end;
.... end behav;
@datang
Thank you so much. I try to change the block IO protocol of function A and I can trigger when function A starts and stops. But this have a small problem, when i change the block IO protocol of function A, latency of top module increases.
