Visitor sgrandpre
Align outputs from HLS function so they are valid on the same cycle
I'm writing a function with multiple outputs in HLS.  Since I want all of the outputs to be valid on the same clock cycle, I put them in a struct.  HLS breaks up the struct into multiple output ports, which is fine - but each one gets its own valid signal generated, and they are not all valid at the same time.  Is there a way to direct HLS to wait until all outputs are valid to send them?
Re: Align outputs from HLS function so they are valid on the same cycle
Hey @sgrandpre,
I think the easiest option is to check if the set_directive_data_pack optimization works for you. It's documented on page 456 of UG902, but you basically just want to add the following into your function:
#pragma HLS data_pack variable=<your_struct_variable_name>
The other option I might recommend for sending the variables at the same time would be to just declare a temporary struct internally and wait until the end to copy them to the output struct.
I hope one of those two options works for you. If not, I might be able to investigate more thoroughly if you could share an example in code.
Nicholas Moellers
Xilinx Worldwide Technical Support
