Alveo U280 not present in Linux Ubuntu Vivado installation
I posted same question yesterday for Windows.
Now I am trying to use SDAccel.. which only works in Linux. So I am installing everything again in Linux Ubuntu 18.04.
Alveo U280 is missing in both Vivado and Vivado HLS.
 Benedetto
Versions:
Vivado HLS 2019.1.3  build  2642998
Vivado v2019.1.3 (64-bit) SW Build: 2644227 on Wed Sep 4 09:44:18 MDT 2019 IP Build: 2633630 on Wed Sep 4 12:30:14 MDT 2019
Re: Alveo U280 not present in Linux Ubuntu Vivado installation
HI @benedetto73 ,
On Linux machine too have you downloaded the latest boards in from Vivado  i.e., from Tools --> click on Download Latest boards ?
Once you have downloaded the boards you should be able to see U280 in Vivado once you reinvoke vivado.
The downloaded board files will be present under ~/.Xilinx/Vivado/2019.1/xhub/board_store/XilinxBoardStore/Vivado/2019.1/boards/Xilinx/
If you don't see U280 in Vivado HLS then follow the same procedure of copying the U280 board files in the Vivado Install location as suggested in other thread for windows machine.
HI @benedetto73 ,
I was missing this part:
"click on Download Latest boards"
  Benedetto
