Alveo U280 not present in Vivado HLS
There is no U280 in Vivado HLS (U200 and U250 *are* present).
Note that Vivado *does* have all three, including U280.
Vivado HLS   Version 2019.1.3   Build 2642998
Vivado v2019.1.3 (64-bit) SW Build: 2644227 on Wed Sep 4 09:45:24 MDT 2019 IP Build: 2633630 on Wed Sep 4 12:30:14 MDT 2019
Runninng on Windows 10.
Re: Alveo U280 not present in Vivado HLS
Hi @benedetto73 ,
Please copy the U280 files folder present in AppData location (C:\Users\<User_Name>\AppData\Roaming\Xilinx\Vivado\2019.1\xhub\board_store\XilinxBoardStore\Vivado\2019.1\boards\Xilinx) to the install location (C:\Xilinx\Vivado\2019.1\data\boards\board_files).
After this close, all the HLS opened sessions and then try reinvoking Vivado HLS, this time you should be able to see the U280 board in the device selection
Hi @benedetto73 ,
Can you please invoke Vivado and see if you are able to see the U280 board there ?
If you don't see U280 board in vivado, then from Vivado itself please goto Tools --> click on Download Latest boards.
This would download the latest boards, once the download finishes please reinvoke vivado & Vivado HLS and see if you are able to see the U280 board in the device selection windows of both the tools.
Thanks @shameera.
I did as you suggested, no change.
Vivado *does* show the U280.
Vivado HLS *does not* show the U280.
I also uninstalled and reinstalled the entire Vivado suite. Same outcome.
@benedetto73 ,
If you had downloaded the latest boards from Tools menu, then Can you please confirm if you are able to see the U280 board at the below location ?
And also please confirm if you don't see the U280 board at the below location ?
<Install_Path>\Vivado\2019.1\data\boards\board_files
The U280 files *are* present here:
The U280 files *are not* present here:
Hi @benedetto73 ,
Yay!!
I am a happy man. :)
Thanks @shameera , it shows up now in Vivado HLS too! :) :) :)
