Visitor kalopana
Array partition issue
Hello, I am trying to implement 2d (nxn) matrix multiplication (A*B=C) and when lets say synthesizing for n=8 or n=16 i get no WARNING (for array partitioning A and B cyclic factor=4 for dimension 1 and 2 respectively)  but when i do for 32 or above i get
"Unable to schedule 'load' operation ('A_0_0_V_load_2', lab1/project1.cpp:38) on array 'A_0_0_V' due to limited memory ports" and i cannot pipeline II=1.
If I array_partition A and B complete on both dimensions I do not get this WARNING but i believe the cyclic one I chose is correct and it is not supposed to face this kind of WARNING.
I am trying to calculate in parallel 8 cells of C at a time (4 on top-left corner moving rightwards and 4 bottom right corner moving leftwards).
In addition to that, i got some dependence issue for writing on C that i believe it was faulty so I used
"#pragma HLS dependence variable=C inter false" to overcome it ( an extra opinion would be handy for this move)
Any thoughts?
Thank you in advance.
******tool used: VIVADO HLS 2018.2******
---------------------------------------CODE USED-----------------------------------------------
#include "ap_int.h"
#define m 32//A nxm
#define p 32//B mxp
#define n 32//C nxp
void MATRIX_MUL(ap_uint<8> A[n][m],ap_uint<8> B[m][p],unsigned int C[n][p]){
unsigned int tmp,tmp1,tmp2,tmp3;
#pragma HLS ARRAY_PARTITION variable=A complete dim=2
#pragma HLS ARRAY_PARTITION variable=A cyclic factor=4 dim=1
#pragma HLS ARRAY_PARTITION variable=B complete dim=1
#pragma HLS ARRAY_PARTITION variable=B cyclic factor=4 dim=2
#pragma HLS ARRAY_PARTITION variable=C cyclic factor=2 dim=1
#pragma HLS ARRAY_PARTITION variable=C cyclic factor=2 dim=2
for (int i=0 ; i<n/2 ; i+=2)
for (int j=0;j<p;j++)
#pragma HLS unroll factor=2
#pragma HLS pipeline II=1
tmp1=0;
tmp=0;
tmp2=0;
tmp3=0;
for (int k=0;k<m;k++)
tmp+=A[i][k]*B[k][j];
tmp1+=A[i+1][k]*B[k][j];
tmp2+=A[n-1-i][k]*B[k][p-1-j];
tmp3+=A[n-2-i][k]*B[k][p-1-j];
C[i][j]=tmp;
C[i+1][j]=tmp1;
C[n-1-i][p-1-j]=tmp2;
C[n-2-i][p-1-j]=tmp3;
Re: Array partition issue
@kalopana This should be possible with cyclic. It looks like HLS is not able to handle the unroll in the second loop.
As a workaround, i have unrolled the second loop manually and we can achieve II=1 in this case
#include "ap_int.h"
#define m 64
#define p 64
#define n 64
void top(ap_int<8> A[n][m],ap_int<8> B[m][p],unsigned int C[n][p]){
unsigned int tmp11,tmp12,tmp13,tmp14;
L1: for (int i=0 ; i<n/2 ; i+=2) {
L2: for (int j=0;j<p;j+=2) {
// #pragma HLS unroll factor=2
tmp1=0;
tmp=0;
tmp2=0;
tmp3=0;
tmp11=0;
tmp12=0;
tmp13=0;
tmp14=0;
for (int k=0;k<m;k++) {
tmp11+=A[i][k]*B[k][j+1];
tmp12+=A[i+1][k]*B[k][j+1];
tmp13+=A[n-1-i][k]*B[k][p-2-j];
tmp14+=A[n-2-i][k]*B[k][p-2-j];
C[i][j]=tmp;
C[i+1][j]=tmp1;
C[i][j+1]=tmp11;
C[i+1][j+1]=tmp12;
C[n-1-i][p-2-j]=tmp13;
C[n-2-i][p-2-j]=tmp14;
Visitor kalopana
Thank you for your response. I also came up with a similar solution. I just wanted to confirm that it was not a logic error and the tool gets confused in some cases.
