Axi-stream bus width not work up to 1024x8 bits or more
Dear,
I have a image AI accelerator project required big bus width of AXI-Stream protocol. I have tried many versions of VIVADO HLS version from 2016.2/2016.4...  to 2018.4, but they are all compiled failed by big AXI-stream bus width ? I also try to change the HLS source code to extend the bus width, but it also failed at last.
General image AI accelerator will input 3 channels 24bits (each channel 8bits), after some convolution layers, it will be up to 1024 channels (1024x8 bits). If Vivado HLS could support big bus width, I think that AI accelerator could easy be carried out.
Any comment?
joancab
If I got your question right, you want a bus for 1024x8 bits, so 8192 bits, right? As far as I know, AXI4 buses go to 1024 bits, so, it looks like you are asking for too much
Yes, 8192 bits. You mean that the AXI4 specification limits the maximum bus width to be 1024bits?
richardhead
AXIS has no tdata limits, but Why would you want 8196 bit interface? what are you trying to do with such an extreme  interfacE?
joancab
@richardhead The bus width is limited, isn't it?
richardhead
@joancab
There is no limitation in the AXI spec, TDATA can be any width dividisible by 8.
There may be limits on widths in the Xilinx IP. But 8192 bits wide is VERY wide. The widest bus I have seen considered would be 512 bits for a 100Gbs Mac. Why do you need 8192 bit interface? Why cant the channels be interleaved through time?
joancab
@richardhead , you talk about the spec and you are right. Then, unless writing all AXI-related in HDL, when it comes to the available blocks (interconnects, DMA, etc.) limitations come up. For example, the AXI interconnect:
Interface data widths:
  • AXI4: 32, 64, 128, 256, 512, or 1024 bits
