Bitwise and of ap_uint limitation
I run into problem when do logic bitwise and on wide integers. They only seem to work up to 64 bits.
const int z=70;
for(int i=60;i<z;i++)
	ap_uint<z> x=1;
	ap_uint<z> t1=x<<i;
	ap_uint<z> t2=x<<i;
	bool r=t2.And(t1);
cout << "ap_uint shift " << i << " bits left, (" << t1.toStringUnsigned(16) << ") bitwise AND (" << t2.toStringUnsigned(16) << ")=" << r << endl; }
This outputs:
ap_uint shift 60 bits left, (0x01000000000000000) bitwise AND (0x01000000000000000)=1
ap_uint shift 61 bits left, (0x02000000000000000) bitwise AND (0x02000000000000000)=1
ap_uint shift 62 bits left, (0x04000000000000000) bitwise AND (0x04000000000000000)=1
ap_uint shift 63 bits left, (0x08000000000000000) bitwise AND (0x08000000000000000)=1
ap_uint shift 64 bits left, (0x010000000000000000) bitwise AND (0x010000000000000000)=0
ap_uint shift 65 bits left, (0x020000000000000000) bitwise AND (0x020000000000000000)=0
ap_uint shift 66 bits left, (0x040000000000000000) bitwise AND (0x040000000000000000)=0
ap_uint shift 67 bits left, (0x080000000000000000) bitwise AND (0x080000000000000000)=0
ap_uint shift 68 bits left, (0x100000000000000000) bitwise AND (0x100000000000000000)=0
ap_uint shift 69 bits left, (0x200000000000000000) bitwise AND (0x200000000000000000)=0
Now, there is no reason for this to happen..
Re: Bitwise and of ap_uint limitation
@cyviz,
The line, bool r = t2.And(t1);, is an implicit conversion from a wide (>64bits) ap_[u]int  to a builtin C/C++ integer types (ap_uint<70> to bool), which is not supported by HLS. The following code works as you expect:
const int z=70;
 ap_uint<z> x=1;
 ap_uint<z> t1=x<<i;
 ap_uint<z> t2=x<<i;
 ap_uint<z> res =t2.And(t1);
 bool r = res.to_bool();
And the output:
ap_uint shift 64 bits left, (0x010000000000000000) bitwise AND (0x010000000000000000)=1
ap_uint shift 65 bits left, (0x020000000000000000) bitwise AND (0x020000000000000000)=1
ap_uint shift 66 bits left, (0x040000000000000000) bitwise AND (0x040000000000000000)=1
ap_uint shift 67 bits left, (0x080000000000000000) bitwise AND (0x080000000000000000)=1
ap_uint shift 68 bits left, (0x100000000000000000) bitwise AND (0x100000000000000000)=1
ap_uint shift 69 bits left, (0x200000000000000000) bitwise AND (0x200000000000000000)=1
More information is available on page 628 of UG902.
Nicholas Moellers
Xilinx Worldwide Technical Support
Scholar u4223374
Try replacing your shifts with direct assignment of different bits (eg. using the range() function). I've got  feeling that C does some odd things with the shifts (it's been a while since I tried that), possibly related to your second argument being a C integer rather than one of the ap_int types.
@cyviz,
const int z=70;
 ap_uint<z> x=1;
 ap_uint<z> t1=x<<i;
 ap_uint<z> t2=x<<i;
And the output:
Nicholas Moellers
