Voyager
Voyager
Boolean type in HLS
Sorry if this question has been resolved before but I couldn't find it... seems pretty simple but I'm trying to work in HLS with a function with a boolean as an input argument but when I try to synthetise it's giving me the error: "bool type can't be resolved"
I tried to include the most common libraries but didn't work what library I'm missing?
Oh ok. I thought you were using C++. I use ap_fixed for C++
According to the user guide, page 203, you can use this :
#include “ap_cint.h”
typedef uint<1> data_bool;
or
typedef uint1 data_bool;
and
bool variable_1;
I hope this solves the problem.
Try using
#include <ap_fixed.h>
typedef ap_uint<1> data_bool;
then you can do this
data_bool variable_1;
instead of :
bool variable_1;
I hope this would work as a temporary fix until someone comes up with a better solution.
Voyager
Voyager
Thanks for your answer ayhamzedan, I tried it but didn't work, it couln'd find ap_uint<1> type...
Just to clarify, I'm just trying to add to a C function an input argument which be synthesized as a single signal line, and for that I'm trying a boolean type...anyone knows how to achieve that?
Thanks in advance.
Advisor
Advisor
Ah, the problem is that you're using C rather than C++. For C, you need this:
#include <ap_cint.h>
Or you can just rename the file extension to .cpp instead of .c, and then you can use the ap_int.h header and the typedef in @ayhamzedan's post. Using C++ should also give you a native boolean type (I'm pretty sure I've used that before, although normally I still just use ap_uint<1> as a replacement) which will avoid the need for typedefs.
or
and
bool variable_1;
Voyager
Voyager
Hi, thanks, yes, I did check it, and it's working just including the “ap_cint.h” library and after using the 'bool' type.
Best regards.
