Bug of vivado hls
I have been working on xfpencv in vivado hls its throwing me an error of include files missing, which got corrected if I changed the path of include files in the required header file codes which have been provided by you. Its practically impossible to correct the path always at all the time. Kindly look into this and make sure that we can include header files with a relative path instead of a global path. Is there any alternative to fix this?
shameera
Hi @sivani.pentapati ,
Please confirm if you have followed the steps mentioned at chapter 4 of UG 1233 while using OpenCV libraries.
