Visitor esi2st
Burst access with longer data types vs shorter data types
I am doing a project where I am reading and writing to DRAM (MIG) through a master axi interface. My data types are 16 bits wide. I am using a wide bus interface (128 bits wide)
My question is: Is the bus width efficiently utilized for a high burst access (128bit x 256 read/write) or is it confined by my data type (16bits x 256 read/write) if I use memcpy to copy 256x(128/16) values (corresponding to 128 bits x 256 read/write) from my data buffer? or do I have to pack up my data in 128 bit ap_uint types?
Re: Burst access with longer data types vs shorter data types
Hello @esi2st,
Unfortunately, with HLS, you have to have the ports match what you would be connecting to. In this case, the 128-bit interface to the MIG/DDR IP. So yes, you would have to concatenate the 8 16-bit words into the single 128-bit interface. Else, as you mentioned, the efficiency of interface would be low with only 16 bits being used.
OK, hope this helps,
Scott
Hello @esi2st,
Scott
