C code not synthesizable by functions
Hello All,
I have a c program that contains several subfunctions that the main function calls. When I use Vivado HLS to synthesize the main function it works fine, and it also works when I tell the compiler to synthesize a particular subfunction.  This works for most subfunctions, however when I try to synthesize some of the sub-functions I get this error:
CRITICAL WARNING: [SYNCHK 200-61] ../benchmarks/chstone/adpcm/adpcm.c:585: unsupported memory access on variable 'x' which is (or contains) an array with unknown size at compile time.
INFO: [SYNCHK 200-10] 1 error(s), 0 warning(s).
CRITICAL WARNING: [HLS 200-70] Synthesizability check failed.
This only happens for two of the sub-functions. I think that the inputs of the subfuctions are not supported by vivado hls and therefore it causes the error, Is there a way to modify the code to be able to synthezise these functions?
The not synthesizable functions are:
filtez
upzero
the c source file is attached
Best Regards,
Raul
I think if you change the pointers to arrays with sizes, it should work:
int filtez (int bpl[6], int dlt[6]);
etc.
etc.
Hello Joseraul,
I also found an AR (https://www.xilinx.com/support/answers/59829.html) and another forum post (https://forums.xilinx.com/t5/Vivado-High-Level-Synthesis-HLS/C-code-not-synthesizable-by-functions/td-p/732796) about the error messages.
I am not sure if you already read them, but I wanted to make you aware of them.
Chris
