Observer rendres
Camera Calibration consumes too many BRAM
Hi!!
I am trying to develop a system that uses a stereo pair and a camera in monochrome. Because of that I need to calibrate the three of them.
I use the function InitUndistortRectifyMapInverse which doesnt consume to many resources. However, when I use the hls::remap function, I need to give it <64> (WIN_ROWS field). As I'm using a Zedboard, it only has 140BRAM_36K (or 280BRAM_18K). I can calibrate all the cameras perfectly but hls::Remap uses too many resources for the RGB cameras. If I'm using the monochrome camera my core uses 13% of BRAM and 25% of DSP (this is because of the camera parameters, which are apfixed) but the core of one of the cameras (obviously 3 channels image) uses 36%, as expected it is 3 times more because of the 3 channels used for RGB.
My question is: is there any method to remap the image using a 1 channel map and then restoring the color returning to a 3 channel image?
I've seen several examples using the remap function, in the majority of the examples WIN_ROWS are 8 or 16. Why do I need to use 64? My image resolution is 640x480
Thanks and sorry for my english. It has been difficult to explain...
Scholar austin
Re: Camera Calibration consumes too many BRAM
r,
No apology needed:  you are completely clear in your post.
I would look at the resulting calibration data for the monochrome vs. color.  I would first attempt to perform the monochrome calibration, and the use that triplicated for the color situation.  No need to store copies of calibration, re-use the monochrome.  It may be difficult to do in HLS, but might be trivial if coded in verilog (VHDL)...
Austin Lesea
Principal Engineer
Xilinx San Jose
Scholar austin
r,
Austin Lesea
Principal Engineer
Xilinx San Jose
Voyager
Voyager
Hey @rendres
Who forces you to do that?
The following works just fine here:
    hls::Remap<16, 480, 640, HLS_8UC1, HLS_8UC1, HLS_16SC2, HLS_16SC2>(src, dst, m1, m2);
... is there any method to remap the image using a 1 channel ...
You can simply use grey image data (e.g. HLS_8UC1) instead of RGB data (e.g. HLS_8UC3).
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
回复: Camera Calibration consumes too many BRAM
@rendres
hls::remap is designed for streaming operation for cameras with small vertical disparity.
It contains an internal linebuffer to enable the remapping that contains WIN_ROW rows of the input image.
When the difference between the origianl image and the target image in the vertical direction is too large,
the number of rows(WIN_ROW) required to store the orignal image will become larger, which may lead to the
shortage of FPGA resources(RAM).
In your case, you can only solve the problem by designing your own function or HDL code.
In may opinion, the existence of the hls::remap fuction only increases the number of video libray fuction in hls.
In practical applications, images are offten large, and the use of hls::remap is often limited.
Visitor rich_sheep
Hey @hpoetzl
did you use this function to remap cameras in HLS?
I wonder how to storage and transfer map1 and map2 in HLS, could you tell me?
i've tried so many times and it still not work.
much appreciate~
Visitor topshang
hello ,
        did you solve the problem about  how to storage and transfer map1 and map2 in HLS?
        thanks for reply.
