Voyager
Voyager
Can I reset static variables in HLS?
Let's say I have some HLS block that reads from an AXI stream and processes a number of consecutive data to produce a result.
I have a counter implemented as
int  static  i = 0;
So when it reaches some value, the result is written to the output and reset to 0.
But, is there any way reset it from the outside?
Re: Can I reset static variables in HLS?
Hi johnvivm
Add the following Pragma:
static int counter;
#pragma HLS RESET variable=counter
It will let the tool know that you want the variable to be reset when the ap_rst is assrted. otherwise ap_rst simply puts it in the original start state.
Hi johnvivm
static int counter;
