isae
Can't find assert library
I've just installed Ubuntu 18.04LTS because csim is soooo slow on Windows 10... I installed Vivado 2020.1.
When I compile my project with the GUI, I got this cryptic message :
INFO: [SIM 211-4] CSIM will launch GCC as the compiler.
ERROR: [SIM 211-100] CSim file generation failed: compilation error(s).
INFO: [SIM 211-3] *************** CSIM finish ***************
5
while executing
"source /home/adion/bottom-up-approach/kem/hls/kem_150MHz/Reference_Version/csim.tcl"
invoked from within
"hls::main /home/adion/bottom-up-approach/kem/hls/kem_150MHz/Reference_Version/csim.tcl"
("uplevel" body line 1)
invoked from within
"uplevel 1 hls::main {*}$args"
(procedure "hls_proc" line 5)
invoked from within
"hls_proc $argv"
Finished C simulation.
When I try in a terminal with a tcl script, it's a bit more detailed :
In file included from ../../src/rng.h:16:
../../src/gf.h:12:10: fatal error: 'assert.h' file not found
#include <assert.h>
1 error generated.
C preprocessor failed.
while executing
"source kem_150MHz_Reference_Version.tcl"
invoked from within
"hls::main kem_150MHz_Reference_Version.tcl"
invoked from within
invoked from within
"hls_proc $argv"
So apparently, Vivado HLS doesn't find the library "assert.h", which is a standard C library. I put assert statements in a lot of places in my code, for variable size loops, as recommanded in the user guide...
So does somebody know what is this problem and how to solve it ?
isae
I solved it.
GCC is not installed with Ubuntu, but Vivado consider that it's installed because it's Linux...
So I just installed GCC, and it solved that error.
isae
I solved it.
