Cannot add zcu104 in Vivado HLS
Hi all,
We have just bought a ZCU104 board and I intend to try it with some simple examples with Vivado HLS. I have downloaded the latest Vivado Design Suite - HLx Editions - 2018.2 and applied a 30-day evaluation license. After I start HLS and open an old project, I find there is no ZCU104 in the board list, but ZCU102 and ZCU106 are available. Has anybody else met this before, it's pretty weird because I already installed the device family Ultrascale+mpsoc during installation. Besides, it seems I cannot create a new project from scratch in HLS 2018.2.This problem is also mentioned in:
https://forums.xilinx.com/t5/Vivado-High-Level-Synthesis-HLS/Cannot-create-new-project-in-Vivado-HLS-2018-2/td-p/877341
Attached is the supported board list.
Re: Cannot add zcu104 in Vivado HLS
@bill_g
Can you try adding the zcu104 Board files to the C:\Xilinx\Vivado\2018.2\data\boards\board_files\ folder?
Nupur
Dear Nupur,
Thanks for your reply. I have just checked the location you mentioned, the zcu104 folder is there along with zcu102 and zcu106. What should I do next?
I have also tried Vivado 2017.3 and 2017.4, but the ZCU104 is still not in the board list. So I cannot do anything on this board.
Why such an obvious bug was not noticed by Xilinx when they released the software? I have also tried other versions of HLS, but none of them can add the ZCU104 board.
I also have this problem, all the board files seem to be there but can't add 104 to HLS.
Is there any update on how to fix this?
I think it's a bug. However, you can just choose the correct part for ZCU104.Otherwise, ZCU104 can be found in Vivado's boards.
The part number is XCZU7EV-2FFVC1156 which is also not listed in the tools
I looked in Vivado. It seems to recognize the ZCU-104 as part XCZU7EV-FFVC1156 2-e. I will try using this in the Vivado_HLS design
