fiedel
Cannot create new project in Vivado HLS 2018.2
I'm following ug871 to do labs. When creating a new project, after adding test bench files to the project, vivado doesn't respond to click on Next button. Are there tricks here to proceed?
fiedel
Thanks for the reply. It turned out to be I hadn't install the WHOLE library of the devices. After installation, problem gone.
shameera
Hi @fiedel,
I don't see any issues at my end. Can you please share the snapshot of your screen and let us know the OS that you are using.
fiedel
scampbell
Hello @fiedel,
I am just trying to clarify what happened here so we can note that in an answer record. Do you think this was that the device your were attempting to use with the project was not installed, or was that device already installed, but you needed the whole set of devices to continue anyways?
OK, if you had any more information I would appreciate it.
Thank you,
Scott
