kasalala
Cannot open HLS 2018.2
      I install the sdx on my Win10 computer. But the HLS2018 included in the folder only pop up a black window and can't be opened.
      I tried to copy the wscript.exe into the bin folder and input the path of vivado_hls.bat in Command Prompt, but it remind me Permission denied.
shameera
HI @kasalala ,
From the error, it seems to be a permission related issue.
Also, there is no need to run vivado_hls.bat from the HLS TCL console.
You can just change the directory which has all the permissions then directly use the command vivado_hls to invoke HLS in GUI mode.
yangc
Hi @kasalala
Please check the OS is supported OS for sdx which you install.
shameera
HI @kasalala ,
kasalala
Thank you! the previous directory do require administrator privileges, and I reinstalled it in another disk, it works now.
