mrbietola
Change stream data width
Hi i have an HLS block that read from memory with 128 bit as datawidth (2 pixel of 64 bit).
I then need to stream out this data but 64 bit at the time.
What i need to convert the width?
dsakjl
Hi @mrbietola ,
probably you can do something as follow:
ap_uint<128> data = read_memory(...);
queue_out.write(data.range(63,0));
queue_out.write(data.range(127,64));
mrbietola
Hi, thanks for reply, what type is queue_out?
a similar code i tried "broke" the burst reading from the memory.
dsakjl
queue_out is not a data type. It is an hypothetical name for your output stream, which should be of type hls::stream<>.
"a similar code i tried "broke" the burst reading from the memory." What does it means?
mrbietola
Hi, i will try your suggestions.
Broke the burst mean that the burst was not performed if a 2 writes to 64 bit variables are performed later.
I'm helping a collegue of mine, i'm actually not aware of what he tried to do
