Coding style suggestion
Consider a function
void hw_func(hls::stream<TYPE1> &inStream, hls::stream<int_32_side_channel__> &outStream, volatile fixed_point* mem_addr)
#pragma HLS INTERFACE m_axi depth=1500000 port=mem_addr offset=slave
#pragma HLS INTERFACE s_axilite port=mem_addr
#pragma HLS INTERFACE axis port=inStream
#pragma HLS INTERFACE axis port=outStream
#pragma HLS INTERFACE s_axilite port=return
#pragma HLS DATAFLOW
// define some internal streams
hls::stream<fixed_point> tmpStream1, tmpStream2, tmpStream3;
call_sub_func_1(inStream,tmpStream1,mem);
call_sub_func_2(tmpStream1,tmpStream2);
call_sub_func_3(tmpStream2,tmpStream3,mem);
// ... write tmpStream3 to output stream with side channels ...
I am using the m_axi port twice in a DATAFLOW region. Is this allowed?   Like the streams  must be produced and consumed exactly once.
I ran into problems successfully running this function.
I have tested some cases:
  • Dataflow ON: the simulation/hardware is hanging on using this IP. If each sub_func above has II = Latency, there should be no cases of concurrent access to "mem" port right? But still the simulation hangs.
  • Dataflow OFF: requires stream size to be set. I set maximum stream size for each stream. But simulation again hangs / goes beyond 100%. I have other optimizations turned off as well in this case.
Any suggestions for the possible cause of cosim hanging?
Update:
Removing dataflow removes the cosim hanging problem. My previous test was incorrectly reported.
Advisor
Advisor
I'm pretty sure HLS won't be able to figure out dataflow with the system you've got, which explains why it fails.  With Dataflow HLS is trying to run all the functions simultaneously, but it doesn't know how to share an AXI Master between two simultaneously-running functions. As a result, it'll probably refuse to start function_3 until after function_1 has finished - and you'll need one of the streams to include a large buffer.
That might still be acceptable; it'll mean that the AXI Master is utilized almost constantly, so you're getting about as much throughput as you can reasonably expect.
Does the "STREAM" directive automatically "break" the dataflow?
How would I go about inserting a buffer? Would a simple array in between the two functions suffice? I mean an array into which the last stream is read and then a new stream is generated from the array for the next function?
Advisor
Advisor
The STREAM directive works fine with dataflow; in fact that's what I'd use in this case.
Something like:
#pragma HLS STREAM variable=tmpStream2 depth=100
This inserts a 100-element buffer into the tmpStream2 FIFO. If sub_func_1 finishes before those 100 elements are filled, then it releases the AXI Master and sub_func_3 can empty out that buffer, priming allowing for another 100 elements to be read.
this approach didnt work for me, i had to split the dataflow into two sub-functions at the cost of latency
there should be a better way
